im in the process of putting in my motor but i want to shim the pump first. there are no more pics of showing how to do it and was wondering if anyone had any. thanks
where is that located? pics? thanks ian....IJ.;1201605 said:No more than 5mm
If you have the stock pressure based Oil Cooler circuit remember to shim it's relief valve as well.
so i want to shim my oil pump relief spring 5mm and my oil cooler relief spring 5mm?IJ.;1201713 said:
