I'm installing a new water pump and was wondering if there are any tips I should follow. It appears that the previous water pump was installed with some type of rubbery sealant or something, but I see no mention of anything needed for sealing besides the gasket in the TSRM. Is there some sort of sealing substance I should use or is the gasket and a clean gasket surface sufficient? Any other thoughts?
