okay so i tried to research but i keep getting all sorts of answer. my first and main concern is.
1. are the drive shaft yoke different? meaning i cant take the w58 driveshaft and stick it in the r154 correct?
2. speedo cable the same?
3. i have w58 mated to 1jz, i dont need a new flywheel going with r154 do i? i would assume not because it should have the 2j/1j flywheel on there already. i dont know because i didnt do the swap.
4. are the slave cylinder fluid line threads the same?
thanks!
thanks!
