VVTI questions
Vrank!!!
hahahahaha
Dec 17, 2009
136
TX
Curious if there's a way to bypass the speed cut built into the 2jzgte vvti ecu without an aftermarket management or piggyback setup. Anyone done this yet? It will be mated to an r154 if that makes a difference. Also was thinking there should be a section specifically for the vvti engines since they're beginning to be more common. I believe this was mentioned before...
Vrank!!!
hahahahaha
Dec 17, 2009
136
TX
So am I gonna have the same deal with the 1j vvt?i 'Cause someone made me a sweet deal I couldn't refuse on one with an r154 attached and it's on it's way...
Evilempire1.3JZ-GTE
SF what a waste of supras
Jun 22, 2006
1,382
SoCal
If its an auto with ECT built into the ECU you cant cut the speed wire (usually pink wire) you can get a speed defender for it.
if automatic SP1 SP2 will be clamped down at 100mph speed by the defender so it wont trip an error code for SP1 SP2 missmatch or activate fuel cut at 120mph limit.
