VVTI intake cam gear - need help removing
steve_mk3
5
middletown, NJ
Could use some help before I break something. I am dis assembling my 2JZ GTE VVTI to rebuild and having a problem removing the intake cam gear,
I am using the 2Jz Ge VVTi manual,
- Removed the Screw Plug with a 14mm hex wrench.
- Tried to remove the set bolt with a 10 mm hex wrench. Turning it counterclockwise - I broke the hex wrench.
Am I doing this correct?
Any insight would be good, I am a bit stuck right now.
Thanks
Steve
steve_mk3
5
middletown, NJ
I I am using the following TSRM -
http://home.wjw.co.nz/Toyota/supras/EM (2JZ-GE).pdf
Page EM14, towards the bottom shows the VVTI Cam Gear.
Page EM18 shows exactly what I am trying to disassemble.
I was able to remove the 14mm Plug (counterclockwise)
I am trying to remove the 10mm set bolt.
I did have a 10mm 6 point hex wrench from sears (looks like a Allen wrench)
I am trying to turn the set bolt counterclockwise - it did not budge
I then used a breaker bar and broke the 10mm hex wrench!
Thanks for your help!
Steve
allen600
166
oakdale
Mine came off fine I'm not sure that your doing anything wrong just sounds like you found a tough bolt! It should only be at 60 ft-lbs so it will be tough but shouldn't be breaking tools, like he said ^^ try a better socket and give her another go!
steve_mk3
5
middletown, NJ
Stopped by autozone on the way home from work
Duralast > Craftsman
It was on quite a bit more than 60 - its off now.
Thanks
steve
