VPC
Disced
Pie + NYQuil = FTW
Edmonds, Wa
On the VPC, there are 3 connections.. One set is wired into the ECU; easily done. That one is by itself.
The two that come from the VPC together is where my problem lies.. It seems I didn't get the full harness... I have the temp sensor and the boost sensor, which plugs into one.. Butt...
Anyone have the hard-wiring for the third plug? Or do I even use this third plug?
Thanks,
Kyle Ackerman
Disced
Pie + NYQuil = FTW
Edmonds, Wa
Na man.. I mean.. on the VPC, there are three PLUGS. one of them goes into the bay via temp sensor and boost pressure solenoid.
Then there are two more. One of them came with a harness, one didn't.
The hardwire directions for those four wires, I already wired up BUT i don't have the harness for the second plug. What's it for? DOes it need to be wired up as well or is it for some other device? F-Con or something?
Thanks,
Kyle Ackerman
Disced
Pie + NYQuil = FTW
Edmonds, Wa
Alright; I did a little bit of googling and found out it's for a GCC.
So i'm thrilled! Turbo will be back sooon and running VPC. !
