(VIDEO) nothing turns on on the dashboard,full battery
D7MSupra;1472056 said:
Triple check all the connections. Check all the fuses and relays 4 the ignition. I would think its a connection tho bc nothing turns on. Typical supra owner for ya:3d_frown:
Did you miss the part where he shorted it out?
fify
ehletitrain
Sweet Talker
Aug 6, 2009
Downey, CA
www.facebook.com
checked every singal fuse and they are fine. weird thing whem i connect the light tester to the neg then press it against the manifold the light turned on like it has a positive running through. but all the fuses r fine.
7mLove
Addict
Nov 11, 2009
121
Barksdale AFB, Louisiana United States
did you check to see if you didnt drain your battery when you shorted it out...also doesnt what you said above mean you have a short somewhere still in there and all the current is running through the manni
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
sigh
cheak the main chassie siganle wire it is blue goes to the batteir some times this will come loose or the crimp has gone bad and it just held on by teh wire caseing
chow
S.A. supra
2,405
Buda, Texas
Thats happen to me before. All i needed was a jump.
ehletitrain
Sweet Talker
Aug 6, 2009
Downey, CA
www.facebook.com
Triple check all the connections. Check all the fuses and relays 4 the ignition. I would think its a connection tho bc nothing turns on. Typical supra for ya:3d_frown:
everything is hooked up great. i searched and searched and i cannont find where the relays are.
