Valve cover gaskets
Evilempire1.3JZ-GTE
SF what a waste of supras
Jun 22, 2006
1,382
SoCal
Yes they work there is one little wave or bend in them that is not in the 1JZ streighten it out & it works fine! Add a very fine beed of permatec high temp silcon around the cam shaft bearing bends maybe spread it thin on the seal to should last you a long time.
I also heard the 7M ones work but to play it safe I kept it JZ.
pnutcar
1jz Asshole :)
Jan 25, 2006
299
St. Louis, MO
10secdream;1352205 said:
I used the Toyota gasket stuff (FIPG) and just reused my old gaskets. Seems to work well with no leaks.
I will be doing the same exact thing very soon, ill post my results; hopefully the same as yours!
