using etanol on supras
remkye08
Learner
Oct 1, 2009
82
Round Rock, TX (Austin)
well like 2 weeks ago i put half tank of ethanol and half tank of 89 octane gas and the car seem to get more power and more mpg, plus ethanol is cheaper :)
is it a good idea?
have any1 here tried before ?
8,873
How about more detail, since US pumps are typically 10% anyway. You gain no power from a fuel with lower BTU content, all else being equal. If you are running 89 all the time in your Supra Turbo, you are losing power from stock. The ethanol, if you found something a little higher, will raise octane rating, getting you closer back to stock.
lewis15498
Don't blame ebay cheapass
Sep 28, 2008
1,397
Raynham, Massachusetts, United States
Bad idea. While ethanol can be a great fuel for tuners your fuel system and engine control needs to be upgraded. To do it right you need larger injectors and fuel pump sometimes need to uprade lines and filters for better flow and need to run a standalone.
Gas is Stoich at 14.7:1
IIRC Ethanol is Stoich at 9:1
Somebody correct me if im wrong about the ethanol afr, but its something close to that. Just running ethanol in there with no mods could result in a retardedly lean condition.
BTW most of the cost savings are outweighed by the additional consumption.
Your increase in power was probably founded by 89 octane is insufficient, and the ethanol increased the octane reading.
grimreaper
2,180
Dallas
30% mix of e85 summer blend with pump 93 (says up to 10%ethanol on the pump) leaned me out over a point in af ratios. Not something i would do with out a wideband at the very least for wot. Stock ecu will do what it can do keep vf's inline but i had to increase fuel psi to get things happy. Ive said my piece about converting to full e85 already but for tuning, a stock map with e 85 is going to cut mpg's, not increase.
if a wideband is setup to display lambda in gasoline scale, it doesnt matter what fuel you run. At stoich you'll see 14.7 and you still shoot for 11's-12's at wot or what ever your goal is.
Cz.
CAR > FAMILY
Seattle, WA
You need about 30% more fuel if you're running ethanol in place of regular gas, something that your stock ecu isn't taking into account. Since you mixed it with gas it's not that bad, but it's not really a good solution.
If you ran regular premuim gas like you're supposed to you probably wouldn't have noticed much change.
mkIIIman089
Ohio
Strictly from Toyota's perspective, my owners manual says 15% is the maximum alcohol content in fuel.
8,873
Can you scan that info? I haven't seen it. Then again, I haven't dealt with automotive in some time.
toy_dremer
uneek Supra
Oct 7, 2009
51
Weston, WI
Remember, that gas stations say up too, that doesn't mean there is exactly 10% in there. Besides like lewis said, it is corrosive and will eat up seals on engines not designed to run it. I found a gas station that doesn't have it at all. I use that at every fill up.
mkIIIman089
Ohio
I misquoted actually, I thought I remembered it reading 15%, in fact we are already at the max allowable with 10% ethanol.
attachment.php
remkye08;1467215 said:
what about a mix of 90 pct gas and 10 pct ethanol? it wont eat ur tubes because there is a bigger amount of regular gas
Also remember that they're using additives so that 10% they're using to raise the octane rating doesn't eat your fuel system.
Personally, I wouldn't, the risk of going lean and causing damage far outweighs a little saving at the pump...
EDIT: you also have a thread on your engine making noise, maybe it's DETONATION from doing this...
92nsx
2,957
Clearwater, MN
I'm putting up the :bsflag: on better MPG.
E85 takes more fuel to make the same power. Hint: why it requires 30% MORE then regular pump gas. I think your math shills are off a little.
remkye08
Learner
Oct 1, 2009
82
oh no bro isnt from that i did it once and the problem started like 3-4 weeks after that
and my friend who own a civic he is doing it too for a month already and nothing happens to him
grimreaper
2,180
Dallas
^ civics arent the same. Take a small step back and realize not everything that works on a honda will work on a late 80's supra..
