Here's what I see for viscosity on the oils in question...I added a couple for comparison:
Mobil Clean 5000 5W-30
KV @ 40 deg C = 62.2 cst, KV @ 100 deg C = 10.6, VI = 161
Mobil Clean 5000 5W-20
KV @ 40 deg C = 57.8 cst, KV @ 100 deg C = 8.5, VI = 156
Pennzoil Platinum 5W-30
KV @ 40 deg C = 57.5 cst, KV @ 100 deg C = 10.3, VI = 169
Pennzoil Platinum 5W-20
KV @ 40 deg C = 46.84 cst, KV @ 100 deg C = 8.48, VI = 160
(The Pennzoil Platinum 0W-20 is very close viscosity wise...the VI is 175)
Amsoil Signature Series 0W-30 (the Series 2000 oil is discontinued...this is it's replacement)
KV @ 40 deg C = 56.56 cst, KV @ 100 deg C = 10.3, VI = 173
(The Series 2000 oil is almost identical)
Amsoil ASM 0W-20
KV @ 40 deg C = 49.1 cst, KV @ 100 deg C = 9.0, VI = 163
Red Line 5W-30
KV @ 40 deg C = 62.0 cst, KV @ 100 deg C = 10.6, VI = 162
Red Line 5W-20
KV @ 40 deg C = 55.0 cst, KV @ 100 deg C = 9.1, VI = 145
Per Mobil's FAQ:
Mobil Clean 5000 is not a synthetic or synthetic blend. While it does offer high performance, the base stock composition is non-synthetic.?
That means Mobil Clean 5000 is a Grp III base stock. Pennzoil Platinum is also a Grp III oil...it's extensively hydrocracked, to the point where it is virtually indistinguishable from a Grp IV...superior to Mobil Grp III base stocks IMO. Amsoil is a Grp IV PAO with ester adds. Red Line is a Grp V ester base...the best available. Note the Red Line oils have a VI that is lower for the respective weighs...the ester base stock is the reason. Ester requires less viscosity improvers to maintain the grade range...that means more lubricant by volume in a bottle.
My point is all of the above are excellent oils...all have stout add packs...all will provide (or exceed) the requirements of your engine...all have cold viscosity spec's that are very close to each other. The major difference is the viscosity at ops temp...all of the 30W oils are 10+ cst; all of the 20W oils are at 9.1 cst or less. It gets to a point where you can over think this and start splitting hairs
I'll usually steer someone to the 0W or 5W-30 oils for a stock/moderately modified 7M, 1JZ, or 2JZ motors...they were designed for the viscosities these oils have at ops temp. There is a big difference in viscosity when you go to the 40W or 50W multigrade oils at ops temp...especially when cold...these oils reduce flow to the bearings. However, when you start talking about differences between 20W and 30W multigrades, the differences in hot/cold viscosities is a lot smaller (percentage wise)...both grades will flow plenty good enough to keep the bearings happy. The biggest advantage in the 20W oils is you will see an improvement in gas mileage.
Like I said, the 20W oils may increase consumption and/or valve train noise...it is going to depend on the individual engine. Like MkIIIman said, the 20W oils my also give you a lower pressure when hot...not that it means the oil is not doing its job at design temperatures, but does illustrate the effect heat has on viscosity at temperatures above 100 deg C. Viscosity drops pretty quickly above 100 deg C...the 20W oils are already below engine design viscosity at 100 deg C. IMO, you will need a very good cooler circuit (definite upgrade from stock...full flow, thermostat controlled) to prevent excessive viscosity drop. An oil temp gauge would also be an excellent idea. This especially applies to where we live, OAT wise
All you can do is try a oil and see what happens when you are looking at this class oils. I tried the Amsoil Series 2000 0W-30 and did experience increased valve noise...that is why I switched to GC. It is thicker at ops temp, but still flows very well cold...it cut the noise I was hearing in the cockpit by half.
I'm curious, why do you want to switch from Pennzoil Platinum 5W-30?
