Unknown bolt-on turbo.
suprafredde
160
South of sweden
Bought this blue thing and Im hoping someone has seen its kind before and can estimate its hp limit.
I would rather not take it apart but if I have to so be it.
regards Fredrik
MDCmotorsports
Indy 500
www.MDCmotorsports.com
That appears to be an older to4b, with a 57 trim compressor wheel and an O trim turbine, mated to a CT26 exhaust housing.
The bearing housing is a t4.
The compressor housing was originally used in a Ford diesel application and other off hwy apps.
MDCmotorsports
Indy 500
Its a good turbo, provided it doesn't have any shaft play. Should be able to make the 400's mark with it. I doubt it would be that slow to spool in the ct26 exhaust housing...
As for the wastegate hole, I would port it out the best you can.
suprafredde
160
South of sweden
Has little up/down but nothing shaft length wise. How much should I leave for the flapper to rest on? 1mm?
Thanx for the good news/help Mr MDCmotorsports.
suprafredde
160
South of sweden
Picture below shows my current build state.
Turbo got painted and flapper hole ported out as much as I could, edges rounded and housing clocked so there is a little bit of pre tension on the flapper.
The oil inlet fitting is a hair larger than 7mm id.
Ditching the banjo feed and Im wondering what size hose to use, and if I should put some sort of inlet restriction on the feed?
Where to buy hose and fitting for the 7M block?
Never mind the dirty inlet hose and unfinished valve covers =)
Thanx
suprafredde
