Uneven suspension
iwannadie
981
gilbert, az
I have eibach with tokico blues and my passenger rear side sits higher. The shock/springs are a few years old and when you look at the car from the front or back the pass. rear is visually higher. I can fit 4 fingers between the tire and fender on the driver rear side and on the pass side its maybe a 1" bigger gap.
To make things more confusing I think now that its not consistent. I was in the garage today and looked and it seemed to be sitting level and the gap was equal on each side. The gap on the driver side has always been 4 fingers, that never changes. So I don't think its the driver side sagging down.
Its sitting on level ground with nothing in the car to weigh either side down. The front end is level and none of the shocks seem blown or leaking. I'm not sure how one corner could be higher unless the other 3 are sagging.
Could it be a bushing going bad, upper mount or what? Any advice on what to check or look for?
tErbo b00st
Hard Ass
Mar 20, 2007
185
Iowa City, IA
www.kougakuracing.com
your probably on an uneven surface
your garage is level, thats why the gap is level
iwannadie
981
gilbert, az
My garage floor is level and its also the same way(gap) on any surface I park on. I've backed into and pulled forward into my garage, same gap in the passenger side only.
If you stand directly in front or behind the car you can clearly see the rear corner is higher. Its like someone has a jack under the rear corner and is lifting it an inch.
suspension bolts not tightened while car is on the ground (or just loading the suspension with a jack) can cause this...
steveo
195
Alberta
Just on a off note... How did you like your eibach/tokico blue set up? Fairly good drop? Notice any handling differences? So for hijacking the thread..
iwannadie
981
gilbert, az
When I installed the setup I used a floor jack to lift each corner then tightened the bolts. Maybe I didn't lift that corner high enough when I torqued the bolts.
Would not loading that corner enough cause this problems years after it was installed? Like I said just recently has it been a problem until then it said level.
Asterix
Lurker of Power
32
28
Vienna, VA
Could be the spring rate is higher on that one spring. Of the springs I've measured, 10% difference between two springs in the same box isn't unusual.
Asterix
tErbo b00st
Hard Ass
Mar 20, 2007
185
Iowa City, IA
you said when you were in your garage the fender gap is the same. Hence why I said your garage is level, and the other surfaces you are parking on (when the gap is different) is not level.
iwannadie
981
gilbert, az
Maybe I wasn't clear enough in my original post. The car sits the same no matter what surface it is on, my garage or a random parking lot the passenger corner sits higher.
A. Jay
Search.
Jun 3, 2009
671
Bay Area, CA
When one of my brothers got a lowering kit for his 2000 celica he had a similar problem, the car was leaning to a side. He bought it salvaged so he assumed it was because of that and put some spacers or something idk it was a long time ago but now it's level. My point is that maybe there's something wrong with your car that you don't know about. It happened to my '91 supra, it had negative camber on a front wheel that an alignment couldn't bring into spec. The crossmember was noticeable bent and the strut towers were and inch closer to eachother than they should've been. Or maybe you know your car well, just trying to spark ideas.
iwannadie
981
gilbert, az
Thanks for the thought, I'm pretty sure nothing structurally is wrong with it. It sat level when I first put the suspension on and since then I haven't wrecked it or hit anything at all. I will check closer for anything that looks bent though.
I actually re-torqued the passenger side bolts and the day I did that it was sitting perfectly level again before I touched anything.
I'm now wondering if it is my full tank of gas causing this, I'll wait until its almost empty and check things for a change.
max-89supra(t)
153
vancouver, wa
dude i have the same exact problem, i used b+g springs and koni shocks, fine 2 inch lowered at first and now the passenger side sits lover an inch its driving me nuts!!!!!!!!!!!!!
Pernilongo
LADA is my daily
Jul 15, 2007
446
Los Angeles
hmm. same shit here B+G springs and konis and passenger rear side is higher.
blk92suprat
J Zizzle
Jul 6, 2008
455
USA
When I had stock suspension the RR sat higher then the LR when I measured from the ground to the fender line.
Pernilongo
LADA is my daily
Jul 15, 2007
446
Los Angeles
I dont remember how it was when it was stock, but i also noticed that dampening is different on those sides, one side is stiffer than the other when you rock the car up and down pressing on a fender. i
Edit: i tried again and the lower side goes down independantly from the rest three and the higher side make the whole rear end go down like as if connected to the other side.
