Type f fluid in auto tranny? Mk3 supra
Mk34ullboost
Boost addict
Jul 22, 2012
32
Pinole
I've been thinking of switching to type f fliud because its suppose to not have as many friction modifiers then dextron. Which would result in firmer shifts and less slippage between shifts which would mean quicker shifts also some one please correct me if I'm wrong. Or let me know of any negative affect this could cause. Thanks
Dan_Gyoba
Turbo Swapper
Aug 9, 2007
1,836
Alberta
www.gyoba.com
TSRM Page AT-18 Fluid type specified is Dextron II. Given that this is what Toyota specifies for correct operation of the automatic transmission, I would not put in type F fluid. You are likely to incur some undesirable consequences.
If you want quicker shifts with less slippage, then you need to change the solenoids which control the valves.
