Two CT 26's what to do?
Devin LeBlanc
1,830
Las Vegas NV.
ok, Heres my dilemma. I have two CT 26's one of them has no shaft play but the compressor wheel is all chipped up. The other one has quite a bit of shaft play but the compressor wheel is in perfect condition.. What I am wondering is if I can take the compressor wheel off the bad turbo and put it on my good turbo without having it all balanced.. Aren't the compressor wheels and turbine wheel/shaft independently balanced? I don't see how they could be balanced as a whole as there is no keyway on the compressor wheel for it to not rotate on when putting it together.
So turbo experts tell me what you think..
Thanks
Devin LeBlanc
1,830
Las Vegas NV.
Thought I would follow up on this post.. I got my car running with the compressor wheel swapped and it worked! Smooth as can be, Nice spool sound and hits boost hard! We tuned it today on 9 lbs boost and it made 219WHP 208WTQ
This is on a NA Block, Pistons, and cams.. Running GTE Electronics, 440CC injectors and intake manifold along with all AN lines for the turbo feed and drain! Glad it worked :)
http://www.youtube.com/watch?v=wDoBR07ZtlQ
