Turbonetics T72, Garrett T67 or Precision PT68?
super.secret.supra.club
1,304
San Diego, CA
so i have 3 turbo to choose from since mine just broke. i had a Garrett T67 with a .68 rear housing. im looking to get a .81 rear housing with the turbo that i choose.
these are all journal bearing.
Turbonetics T72
Garrett T67
Precision PT68
this will be going into my 2jz gte swapped 92 mkiii. daily street driven. ive felt the lag of the .68 housing and wouldnt mind a little more.
please help me guys
I love my precisson 6765 and when I had my pt67, I loved it. I don't know what your goals are but the 6265 seems like a perfect street turbo capable of 750rwhp. On my 6765, I make 624 @ 23psi.
1,304
San Diego, CA
Thanks bro, the 6765 or even the 6262 is my ultimate turbo of choice. Unfortunately Christmas shopping has put hole the size of a semi truck through my wallet. All in all I
Sort of leaning into the pt68. It is in used condition but with only a couple thousand miles and a choice of any turbine housing fpr only $600. Not a bad deal if you ask me.
steveyblack
529
Nj
You run a 1.5jz right? Is that on pump/meth? How does the spool? Im trying to run a 6765 on my 2jz. Im hoping for 500+ on pump
The pt67 is an excellent choice and one hell of a deal you got there.
I'm running the 1.00 rear housing. I have the quick spool valve also. I wish I'd went with a little smaller housing, but it's too late to worry about it now.
Stevey, I am on the 1.5jz and it is on meth and 93 octane. I use a 50/ 50 mix that you can buy from summit. It's called boost juice. I'm actually going to turn the boost up and se if I can't make closer to seven hundred on the pump and meth. Wish me luck.
