Turbocharger FAQs.
Doward
4,245
Alachua, FL
What is a turbocharger?
Put simply, a turbocharger is a device that uses exhaust gas energy to drive a compressor wheel located in the intake tract, to pressurize the intake, and allow the engine to ingest more air than it would otherwise be able to do.
How does a turbocharger work?
Exhaust gas drives the turbine, which spins a compressor wheel via the turbine shaft.
That's great. How much boost can I run on a stock CT26?
On a stock motor, I recommend no more than 12-13psi of boost from the CT26.
