Turbo Size, Type? Gasket type needed?
Intrnlstorm
One Jizzle
Aug 27, 2006
123
Schenectady, NY
I have a turbo that came with my car. The Previous owner said
"The turbo is a Full-Race Garrett. It's basically a GT35 on the cold side and a GT40 on the hot side."
Here is the information that I can give you from the turbo.
- The side that attaches to the exhaust manifold is doubled holed and 3.25" x 2.75" between the mounting holes.
- The exhaust side is 2.75" for the turbine wheel exhaust
- The intake side compressor wheel is 3.75"
- The exit for the compressor side is 2"
- Cold side says A/R .70, EC-1, M-24
- Hot side says A/R .70, M3, G, 3
What turbo is this?
I need both gaskets, Exhaust and Oil, which ones do I need?
Joel
Intrnlstorm
One Jizzle
Aug 27, 2006
123
Schenectady, NY
Some more pictures... WTH is this thing?
Joel
MDCmotorsports
Indy 500
www.MDCmotorsports.com
That's a custom built Garrett turbocharger with the S sized compressor housing and To4S (Also known as TS04) large shaft turbine wheel. Appears to be a P trim turbine.
It should have the 60? something mm compressor wheel in it from the gt40 family. Easy to rebuild, and will make good power for you....
We just need you to pull the compressor housing off and measure the wheel.
