Hi everyone. I have an issue. I have a 1991 Supra turbo just did the head gasket on it. I Have a bearing noise and can't figure it out, but now My manifold was steaming Kind of. I took the down pipe off and watched the turbo as I had someone turn on the car, is there suppose to be a normal build of Water? gases in the " Hot " Side of the turbo, I don't think it is coolant, it's not yellow, or anything, I am worried, maybe I should do a compression test...
Anything would help me at this time, Aslo I have a vacuum leak and that noise, bearing noise, Iuno, But man I just want this car to run the turbo is a ct-26 With a Garret ball-bearing cartridge 62mm turbo upgrade, thanks.
