Turbo blanket
MKIIINA
Destroyer of Turbos
Plano, TX
i used my Boost Logic on a ct26 while i was inbetween turbos. no problems minus needing to remove the studs (not really needed but didnt want to risk tearing the blanket)
worked fine, you could touch the blanket after a hard drive w/o getting burned
sneakypete
Regular Member
Jul 18, 2007
1,129
Central NJ
i used the one from HPF on my SP61GT and noticed huge difference in intake temps. in the fall when the outside temp was around 75F, it dropped the underhood intake temp an average of 18F. in the winter, its dropped the underhood intake temps and average of 20F. the only thing is that i get paranoid after driving the car since i dont have a turbo timer, so i idle a few minutes before shutting the car off.
-pete
