Tuner unable to tune out initial flatspot
need new tires
rubber slinger
Nov 10, 2005
173
Dayton,Ohio
my question had nothing to do with driving a car hard cold, it has everything to do with fueling adjustment when the engine is in different coolant temps.
Krister
Holset lover
May 2, 2005
159
Finland, Europe
You tuner needs to tune the acceleration fuel settings. If the base settings are correct, you could try to change the accel tp sensitivity for instance and see if it makes a difference.
Terry steward
53
benfleet essex
I think I may have an idea on what the problem is,,,,I went out Last night,and she wouldn't start,with light this morning,I went out and wiggled the wires to the CPS,and Map Sensor,,,not sure which wiggle did the trick,,but she started,,could this have some bearing on the problem ??,,,unsure connection ?
