Hey guys,
I can not seperate the transmission free from the engine.
I have done the following:
- removed all 6 pressure plate bolts
- removed the release fork
- removed 8 bellhousing bolts (I don't think there are any more)
- removed the starter (but not the bracket, one of the bolts on the starter has a nut on the other side and I can't remove it working by myself, although it is very loose now)
- loosed the pressure plate and moved it towards the transmission (it moves around freely)
Also the bottom gasket has slipped out and I am able to have a large gap between the engine and bellhousing, what am I missing? Will I need to remove the starter bracket?
