heres a little info on the t56
The transmission uses a hydraulic reverse pull clutch (like the r154), except for the Cobra which is mechanical and had an 11 inch clutch disk (which SUCKS with aftermarket clutches). The synchromesh is made up of brass for the GM and Ford applications, and stainless steel in the Dodge application.
the 93 gm is more sought after due to the really low 1st gear, makes for a better launch susposedly, but has a lower torque rating, and as noted the mustang t56 has a coarse spline clutch, where the gm and dodge use the same clutch, but d/s differes, but as domestics have replaceable u joints its easy to swap the yoke over.
Application Torque Rating 1st 2nd 3rd 4th 5th 6th Rev Input Splines Output Splines
1993 Camaro/Firebird w/2.73 final drive "M28" 350 3.36:1 2.07:1 1.35:1 1.00:1 0.80:1 0.62:1 3.28:1 26 27
1994+ Camaro/Firebird 450 2.66:1 1.78:1 1.30:1 1.00:1 0.74:1 0.50:1 2.90:1 26 27
1993-1995 Dodge Viper 550 2.66:1 1.78:1 1.30:1 1.00:1 0.74:1 0.50:1 2.90:1 26 30
Mustang Cobra 450 2.97:1 2.07:1 1.43:1 1.00:1 0.80:1 0.62:1 3.28:1 10 31
