I've just got my car running again after some upgrades.
Its got an FMIC, FFIM w/Accufab TB, Electric cooling fans, Aeromotive FP regulator set to 42-43psi at idle?- pulsation dampener eliminated. Everything else is still stock.
I have the 3 wire TPS on the accufab wired as best I see fit using the diagram in the TSRM. http://www.cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?S=FI&P=101
VC - Voltage reference/ 5V to TPS
VTA - Sigal back to ECU
E2 - Ground
What does IDL do?
With the TPS hooked runs fine at idle. But at anything other than idle it cuts in and out/revs up and down.
With it unhooked it runs ok at any RPM. But under WOT I get no feul enrichment...runs at 15-15.5 AFR at wide open, which is bad.
Is there another way to wire the TPS or do I need to go ahead and get myself the MAFT-pro thats been on my list?
Sorry for the lengthy post...did my best to explain all I know about whats goin on. If you have any questions feel free to ask.
Thanks so much in advance for any help!!!
E2 - Ground
What does IDL do?
