I know that there are a ton of TPS threads so I'm sorry for adding yet another one. I'm having TPS adjustment trouble and am wondering if anybody can help. I've followed the TSRM as well as this thread: http://www.supramania.com/forums/showthread.php?t=97689. I really hope that I'm doing something stupid because this is driving me nuts.
I have a relatively new (8k miles on it) TPS sensor but for the life of me, I've never been able to calibrate it. I've probably tried 4-5 times since I rebuilt the engine. I've tried both with the throttle body in the car and out of the car. I've checked to make sure that my throttle stop is in contact with the throttle body. I have no codes.
It always seems that one of the values is off. I think the biggest problem I have is right from the get go. I cannot get the my meter to read 0L infinity when the sensor is completely counterclockwise during the first step of calibration. The sensor starts by reading resistance and not an open. I've tried two different meters (a Fluke digital and an analog). When i turn the sensor clockwise I can get an infinity reading, but per the TSRM this is completely opposite of what should happen - I should start with infinity and then deflect (resistance) as I turn it clockwise, right?
So I was looking up the correct part numbers on the EPC and ran across two questions:
- I have an 89T, built in 02/89. According to the EPC that means that I use TPS model number 89452-20050, which was used until 03/89. This is the new TPS that I have. Note that I never saved my original TPS so I can no longer look at that model number.
- My throttle body model number is 22210-42270 (the top of the throttle body says 42270 9B16 so I assume this is the model number). According to the EPC, this throttle body was produced from 08/88 - 5/93 and is for use with the turbo auto tranny models (I have an auto that I've converted to manual).
So my first question is if I have a throttle body that didn't change from 08/88 - 5/93, what did Toyota change that required the use of a different model TPS sensor in 03/89?
My second question is could it be possible, since my car is right on the cusp of the TPS change, that I should try the 14050 TPS model number?
