Okay, here's the situation. I know I've got some sort of leaking in the head. It's signs of the beginning of a BHG, but everything has been done properly. HKS 1.5mm metal head gasket, torqued down properly with ARP hardware. You do the magical blue test tube radiator test and the magical blue liquid turns green. I'm thinking though that it may not be the head gasket, but the head having developped a crack. I looked through the receipts and found 3 other head gasket replacements prior to the HKS. Would that make sense then? I'm ripping the head off anyways, so it will only be a matter of time to find out for sure.
Anyways, while ripping the head off though, I'm thinking, hey, why not make this better? Throw in some drop in cams at the very least, but thinking a full top end build with springs/retainers/valves/port n' polish. Just want to know if anyone's done this and did they find it worth their time/money.
Also, I don't get tons of time off. Thus, the car will be ripped apart and put back together over the span of probably a few months. Crappy part is the most I'll have for shelter is a home built tarp tent like shelter. It's definitly big enough for the car to fit in as well as a work bench in the back, but it will still be semi out in the elements. Is there something I need to do to ensure nothing happens to the block while the head is off? Is this just a bad idea period and should I try and have the head back on ASAP?
Any feedback would be super.
