Too much crankcase pressure??
DarkOne0
Houston
So i noticed that recently my 1jz has been leaking oil from the oil cap and the rubber hose near the turbos. Any idea what it might be? I'm guessing maybe the PCV valve? I think I replaced it when I did the swap 4 years ago. One time I also noticed the oil dip stick sticking out a little bit. I figured maybe I didn't put it in all the way the last time I checked the oil level. Now I am wondering whether there is some other issue.
I recently replaced my cam seals because they were leaking. At the same time I installed some adjustable cam gears and adjusted the exhaust side 3 degrees negative. Could that be causing the issue? I never noticed this before I installed the cam gears.
Any ideas?
Rollus
593
Paris, France
I have the same problem on my 7M. Running forged pistons thought, high piston to wall clearances won't help. Oil/oil vapor are leaking wether from crank seal, or PCV nipples on cam cover.Dipstick tube is oily as well.
It's eating 1.7l/1000km, that's 2,89quarts/1000 miles :S
