The tire pressure on the Supra says 28 psi.
I assume thats with a 35 psi max factory tire and I assume most car tires have around 35 psi max.
I have General tires with a max 44 psi.
When a tire has a higher max pressure of 35 psi do you still set the psi to factory setting?
I am having more wear on the sides then the center. The center is good and the sides are down the wear mark.
I have the same question/problem with my 96 Camry and problem
My Traction TA's always wear out on the out side part of the tread. Its even on both sides of the tire and on both left and right side of car. The tread in the center always had plenty of tread when the sides wore out.
Do I want to increase the tire pressure on this tire to get more center wear? Will going over 29/32 psi cause loss of control.
How do you determine what pressure to set at with a higher psi tire?
