If the crank is truely at zero, and both cams are on their marks, then the CPS should slip in as shown in that second picture somewhere in the middle of the CPS adjustment point..
Then jumper the diag block, Verify no codes are present, and set the timing by adjusting the CPS to 10 degrees with a timing light...
