Throttle Body
Justin
Speakers?
Spokane, Wa
Is there a throttle body I can use that doesn't have the coolant lines or the vacuum lines on it? I'm not using either and I like my stuff to be as clean as possiable?
Any ideas?
shaeff
Kurt is FTMFW x2!!!!
9
Around
block off the little pipe that comes from the large steel pipe at the back of the head. then cut off your coolant passages from the TB and JB weld them shut. (make sure there's no moisture in them) then cap off the nipple to the ISC.
cut off the vaccuum lines too and JB weld, and sand them smooth if you dont want vaccuum ports.
-shaeff
