This is my new project
SiberianDVM
97
Augusta, GA
Hi all
I'm looking forward to building my new project, a ChumpCar racer, based on this 1989 Supra. Once it warms up a bit. :)
First thing is to get it home; right now it is stashed at work. Once I get track car finished and out of the way, the Supra can be trailered home and put up on jackstands for an evaluation. Then it's time to start stripping the insides. I will have many dumb questions, as this is my first ever Toyota.
SiberianDVM
97
Augusta, GA
Thanks, guys. I spent the weekend getting the car on jackstands, wheels removed, and started work on removing the interior. Here is a picture of the inside after I got though most of the gutting, still some more of the dash to remove. Much tidying up remains. :)
No wonder these cars are so heavy: the power drivers seat alone weighed over 100 pounds!! I filled up the back of a long bed PU with trashed interior.
SiberianDVM
97
Augusta, GA
This car has had several aftermarket stereos and alarms installed over the years, so I have some messes to sort out.
1: Is this ground wire adapter plate on the L F strut top stock or aftermarket junk?
2: Is this connected near the L F strut top normally used?
3: Does this unconnected wire laying on top of the air cleaner go to the oil pressure sender? It has a yellow wire. Somebody installed a mechanical oil pressure gauge and the electric oil pressure gauge is not working, but I need to get that pressurized oil out of the cockpit.
Thanks for any help
