Things are looking good...
isnms
United States of America
Oklahoma
i80.photobucket.com
I finally installed all my performance mods. I've had my afpr and mkiv fp sitting on the shelf for a few years.
Things are looking good, I don't think I have to worry about the distortion in my egt signal in a specific log.
I'll up my hi boost to 14 and lean the Rebic out to mid to low 11 afr and call it good.
Mods:
◊ k&n fipk ◊ cartech ic series 2 ◊ defcon ic hardpipes ◊ bosch 110 & blitz ss ◊ lexus afm ◊ pte 550 injectors ◊ ct26 50trim no clip ◊ becauseican 3"dp ◊ exhaust depot 3" high flow cat ◊ raptor 3" cat back ◊ magnaflow 12198 ◊ arp head studs ◊ cometic mls ◊ je pistons ◊ crower rods ◊ clevite bearings ◊ ngk plugs ◊ msd 8.5mm ◊ ati super damper ◊ spec stage2 clutch ◊ fidanza aluminum flywheel ◊ mkiv-tt fuel pump ◊ aeromotive afpr ◊ hks tt ◊ hks evc iv ◊ greddy rebic lc cpu-ii ◊ zeitronix zt-2 ◊ g-tech pro rr ◊ prosport fp gauge ◊
isnms
Oklahoma
i80.photobucket.com
What would be the efficiency limit of a 50trim ct26.
I had read that a stock ct reaches it efficiency level at ~14-15psi.
The 50trim is not that huge an upgrade from stock.
tissimo
Stock is boring :(
Melbourne, FL
75% efficiency till 2.2 bar (~32 psi) at 40lbs/min (roughly 400hp) airflow
So stop being a pussy ;)
shaeff
Kurt is FTMFW x2!!!!
9
Around
[thumb]http://www.turbocharged.com/catalog/compmaps/images/Fig13.gif[/thumb]
Is that in a CT26 housing though, or a larger Garret style housing? He's got a 50trim CT upgrade.
jdub
Feb 10, 2006
10,730
Valley of the Sun
Far different than a T04E housing ;)
You are starting to blow hot at ~16 psi on a CT26 housing. Not even close to the T04E housing map you posted.
tissimo
Stock is boring :(
Melbourne, FL
I highly doubt the housing would have that drastic of a change on the compressor map. I'd say its perfectly fine to 18 psi.
jdub
Feb 10, 2006
10,730
Valley of the Sun
Ummmm...the housing makes a HUGE difference. Compare maps for a small turbo (like the CT26) and a T04 with approx the same size wheel. I think you'll find a smaller turbo plots out to the right and will choke flow.
