testing map sensor
jjh
The Chairman
Louisiana
I was wondering if there was anyway to test a 1jz map sensor to see if its bad? Any help would be great thanks.
Ken
350
Houston, TX
Yes. With the key in the ON position, back probe one of the 3 pins with a safety pin or something. Using your voltmeter, it should read close to 5 volts. Now hook a vacuum pump to the vacuum port of the MAP sensor and confirm that voltage drops as vacuum is applied. It should read approximately 1 volt with 20"Hg of vacuum applied.
