TEMS "fusible link problem" in MK3
gp02a
24
Chicago
Hi:
I searched and read about TEMS posts here. But I don't see it ever mention if there's a fuse plug for TEMS.
My situation is that the TEMS indicator light never on of the MK3 which I bought it recently. Not even ignition switch turned on. So.. I am hoping there's fuse problem. But the fact is I don't even know if there's a fuse for the TEMS system. Can anyone kindly tell me where it's locate (if any) ?
shepfly
15
Ohio
Tems is provided power from 15amp EFI fuse in engine compartment fuse box, so if your car runs, so should tems unless you have a wiring problem. Tems computer also gets a signal through the stop light switch on your brake pedal, do your stop lites work? You could have a bad ground connection, I count seven seperate ones in the manual.
gp02a
24
Chicago
thank you guys. Regarding the stop lites... after the engine is on, and I press the brake pedal, the warning light (above anti-lock brake light) came on ... will that be related? I have not idea what's that light mean.....
osama1234
Noob
Jun 30, 2007
87
vancity
Is this your handbrake light? You can confirm by engaging/disengaging the handbrake. If its the handbrake light and it comes on when you brake, your brake fluid is low.
If the light is orange, and looks like a car with two lights on. Its because one of your rear light bulbs has burned out.
