Taking out dash, anything else to do?
HyRisk
Drifting since ∞
Sep 26, 2005
32
Yay Area
Just got my car, and ran into a couple problems. First off, i didnt like the blue interior...so I just took the dash out. Repainted the dash black, and Im about to put it back in. Im also about to put in a gray carpet too. Before I drop in the dash again, I was planning on taking out the stock alarm, because it simply doesnt work, and I dont feel like even bothering to fix it. Searched, so I hope my research on taking it out will work. Anyways, question being. Is there anything else that I should worry about right now. I noticed that when I fill up the gas the meter still says that I only filled up to about 3/4 of a tank, Im thinking the needle is whack so I should just be able to open the cluster and just raise the needle to the top, right after I fill it up with gas. Im guessing...not sure? Im also wondering If there are any interior instrument panel changes that people have done. Im planning on just doing an LED conversion and making the whole gauge cluster white. :icon_razz Constructive feedback appreciated.
Stretch
Tallest MK3 driver ever!!
Toronto, Ontario
Nows a good time to make sure your heater core is still in good condition ie: not clogged or damaged since you need to take the dash out to reach it.
eric
shaeff
Kurt is FTMFW x2!!!!
9
Around
here's how to remove the stock alarm system. ;)
post #4:
http://www.supramania.com/forums/showthread.php?p=1515#post1515
by the way, you should check out the 'INFORMATIVE LINKS' sticky at the top of the 7M tech section. thats where this link was. :)
and here is most likely the problem with your gas gauge, and how to fix it:
http://www.supras.com/06/techcenter/display.php?QID=47
and for all kinds of other fixes and whatnot, you should check out the SOGI tech tip page:
http://www.supras.com/06/techcenter/techtips.php?wcal4ulogin=a2a84dccf2330ba4e22515d226ad4af1
-shaeff
