t67 1jz.....How much will it make?
Viggs
Slow t67 1j
Jan 28, 2008
57
Buffalo
I dropped my car off today for tuning and I'm curious as what you guys think it will put down when its all done. I will post up the results when I get them but keep in mind that this is being done on a mustang dyno. My fingers are crossed for 600whp. Here's the mod list:
1jz with stock bottom end
BC 272 cams
BC springs/retainers
Driftmotion T67 to4z turbo kit .82 A/R Divided
Full 3" exhaust
Top feed rail
780cc injectors
Twin walbros
Devils own meth kit....100% meth
Stinger
HKS EVC6 controlling the boost
R154
On pump gas, what do you think?
Viggs
Slow t67 1j
Jan 28, 2008
57
Buffalo
On Friday I was given was some bad news. The Tial knockoff wastegate that comes with the Driftmotion kit was leaking quite badly from the diaphragm. So I ordered a new genuine Tial gate which should be here either today or tomorrow. I learned a valuable lesson though, no knockoffs, Ever!! Even if Aaron @ Driftmotion has never had a problem with it, don't risk it.
tissimo
Stock is boring :(
Melbourne, FL
+1 I dont know why a company would push garbage parts.
wardog
R.G.V WARDOG
Jan 19, 2006
564
ALTON, TX
Dude theres somthing wrong with your car man. At 19 psi you should have gotten at least 500rwhp. I got 431 rwhp on a stock ct26- 60 trim and 18 psi. Get that missfire checked out quick. What kind of plugs were you using and whats the gap on em??
Viggs
Slow t67 1j
Jan 28, 2008
57
Buffalo
Here is a vid too:
http://www.youtube.com/watch?v=1wzasZjTIfM
Viggs
Slow t67 1j
Jan 28, 2008
57
Buffalo
Would not having DLI and running wasted spark make it run this weak at 19psi? It doesn't begin to miss though until 19.5-20psi. Air/fuel is around 12-12.5. Before tuning, the shop took compression and leak down: (#1) 161 with 1%, (#2) 150 with 5%, (#3) 164 with 2%, (#4) 166 with 2%, (#5) 165 with 3%, (#6) 172 with 1%. Would new rings give me a big boost in HP?
