so. i have a code 52. now before i get a bunch of replies saying, "its knock sensor signal" or "search" i already know what the code means and i have already tried searching but its very seldom that i can ever find what im looking for with the search function here.
so now that i have that out of the way, allow me to explain my issue. i recently rebuilt my motor and unwrapped and re-wrapped my wire harness as well as did the knock sensor rewire. it is only grounded in one place(the original ECU ground). i have been driving the car for almost a month now and everything was fine, with the exception of a good tune. now, last thursday i got a code 52 out of no where. all my joints were soldered and there is not contact between the core and the shielding net. also,if my rewire was faulty then i should have been getting this code all along which i wasnt. it just came up. is there a way to bench test the knock sensor? or does someone have some known working ones i can get on the cheap? thanks in advance
