Supra 10PSI and Stock Front Lip Question
SupraTrbo89
229
West Chester, PA
I own a 89 supra turbo 5 speed and mods include full 3 inch exhaust, intake and BOV. The head has also been shaved with a new stock head gasket and ARP head studs torqued to 90ft lbs. No fuel system or intercooler or turbo upgrades.
I only plan on running 10psi with my supra and do not plan on going any higher. Can I safely turn the boost up to 10psi with the stock fuel system? If I never plan on going higher than 10psi then is it necessary to mess with 550s/lex AFM/Walboro/afpr? I am aware that fuel cut starts to hit around 12psi and the stock ct26 starts to lose efficiency around 13-14psi.
Also, does anyone know where I can source a good stock front lip? I contacted Aaron and Driftmotion and go no response. I assume the dealer does not sell these anymore.
Thanks for your help.
KKZ SupraMan
163
ohio
shine auto is where I get my stuff as long as you are not hitting fuel cut you are OK turbo probably won't last long
your fine on 10psi if you hit fuel cut turn the boost down a little fuel cut does very from car to car I will say the stock CT probably won't last a real long time.
I got my spec-g bumper and spec-b side skirts and rear addons from shine auto good quality fitment was good
