Well i've been haveing some problems with the supra what happens is the temp. gauge is spiking to the red or very close then dropping back down to normal. So far i've changed the water pump and theremostat (clipped the dodad thingy off and positioned the hole at 12:00)but neither helped. I also checked all the coolent hoses for leaks and found nothing.
I did a compression check this after noon and heres the results
1-130
2-130
3-150
4-150
5-150
6-150
(redid the test twice to double check)
according to the tsrm the 130 meets the min. compession listing and there is no other sign of a blown headgasket (no white exhaustr smoke/steam or milky oil)
and i'm going to bypass the heater core in the morrning to see if that helps but besides that i'm out of ideas
1-130
2-130
3-150
4-150
5-150
6-150
