Stock crank damper limit?
mk3-4-me
669
Milwaukee, WI
Hey so I'm building up my 7m for 600-700 whp. The engine is fully built, only stock part is my crank damper. I'm just wondering if there is a certain limit that the stock damper wouldn't be good anymore as far as horsepower. I know they have the ATI damper, but i was wondering how good the stock one was.
I will be revvin to around 7500 to, I'm sure that will have something to do with it...
figgie
Twin Cities, Minnesot-ah
First off
is it a BRAND SPANKING new stock OEM damper? If it is not, then toss it for High HP. Age causes the "rubber" portion to become..like a rock. Worthless.
ATI damper. Call it a day and have SFI approval also.
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
^ his just has a toner ring cut into it when I had a peek
most people will run fluid damper at higher level's in stead of elastomer
sadly no makes one as of yet but they do make them for the jz's thou
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
Evidently you missed the massive size increase, then.
Backlash2032
1,823
Nebraska
I was actually searching the web to find out why you needed to upgrade your damper at higher power levels.. so thank you IJ!
Sent from my HTC Rezound using Tapatalk 2
NashMan
Aug 5, 2005
4,940
17
Victoria BC
hummm all take your word for it then dave
I know the reg ati is larger then stock how much I can't really remember
must be hard to see the stock timing mark on the front cover with a bigger dampener
Reg one is the same size as stock... if you don't know don't post it's misleading.
SWD Fredester 3
674
baltimore maryland
Glad I read this thread. Guess I'll have to stop by ATI and see what they have. The new one that I have on my build is Reg, I will see what they can do for 700+. Maybe just change out the diameter size?
NashMan
Aug 5, 2005
4,940
17
Victoria BC
mine needed a new belt it was bigger from what I remember, but not much thou.... maybe I say maybe quarter or half inc ?
mine all so need the pullie bolt turned on lath as well
i wounder if they have yet to fix that issue
