1 known good computer, new AFPR set at 35 PSI, new Walbro fuel pump, and getting good spark. Its been down for a month and I can't figure out whats wrong. I jiggled the CPS wires while cranking. I replaced the 100 AMP fuse just because. The timing belt is set at 0 degrees. I checked all the wiring from the computer to the sensors and no shorts/opens. No codes. The grounds under the intake are tight. Anything I'm missing?
