So, I started another thread on a similar subject, but this appears to be new:
Old thread:http://www.supramania.com/forums/showthread.php?t=8952&highlight=steering
Problem: Excessive play in steering wheel.
With engine on or off, when Supra is stopped, I can shake the steering wheel back and forth an good 10 - 15 degrees or so before it feels like I am actually turning the front wheels and I also get this horrible clunking/clanking noise comming from the steering rack.
Also, when driving and I hit a small bump or uneven surface the steering wheel vibrates. I get no other vibration except for steering wheel.
What I have done so far:
New steering rack (same noise, same problem)
New driver's side lower ball joint (helped some)
Suspension/alignment shop says tie-rod ends are tight, wheel bearings are fine and control arm bushings are fine.
New tires balanced and alignment done. Note that the same noise and problem existed before the new tires.
I went home and retested everything the shop did and tested things per TSRM: tie-rod ends are fine, ball joints tested okay, no slop/play anywhere in the suspension.
Also, checked the steering wheel shaft to steering rack, and everything appears normal.
It seems to me that I need to adjust the pre-load within the steering rack itself because that is where the noise and loosness appears to be comming from. Everything else in the steering and suspension checks out okay.
Anyone ever adjusted the steering rack before??? This is a new unit from NAPA.:icon_evil I am still getting the same damned noise and play in steering wheel.
This noise and play and vibration are really starting to piss me off.
Any other suggestions?
