can you run power straight to starter? i had too. i replaced everything from starter switch to relays to fuses and still no crank with the key. so i said fuck it and gave up and ran a wire from my battery to a heavy duty push button switch to the starter and now im good but then again your problem sounds diff. than mine cause i had power everywhere else.
