I need some info on the SSQV flange and a google search didn't help.
I am going to be installing a set of cooleeze pipes. They have the SSQV flange, but I need to plumb my Bosch 110. I want to make a flange that will utilize the seal and c-clip for a constraint, and output a fitting for 1" diameter hose.
I will need to make this on a lathe, but I cannot find any dimensions on it. So, I need someone to measure the flange that is on the bottom of the BOV itself. I need to know the diamater of the foot that gets c-clipped in. That along with the thickness should be enough for me to make what I need.
Even the ID on the female flange that is on the piping would be a help.
If I had the pipes already, I could measure off of that, but they aren't in yet. I want to make this today while I have access to the lathe at work.
Thanks.
Thanks.
