I just finished doing the brakes on my 87 Turbo. I replaced the rotors with drilled brembo rotors, and the pads with axxis ultimate ceramic pads. When doing the brakes, I found that my right front caliper was frozen, so I got a replacement from the junkyard off of an 89 NA. After bleeding the system and going for a drive, the brake pedal felt much more spongy than before. Is this caused bythe caliper in any way? The car seems to brake good, but ABS engages much later than before (not sure if this is good or bad) and the e-brake is not as strong as before, I couldn't even lock the tires with the ebrake while driving (i could before)
Help!
Help!
