sparkplugs
ahmed
150
cleveland
well i made 470hp today but kept blowing out spark. i regapped them to 22 and they laster longer but started to mess up.
what set of plugs can i use that are colder than stock ones.
i forget what kind im using but there from advanced auto there the 2.99 or 1.99 ngk ones.
im running 25 psi.
tissimo
Stock is boring :(
Melbourne, FL
If you're blowing out spark with that small of a gap your coils are probably getting weak. Consider getting a new set (not used) or a HKS DLi.
Supra-Man18
357
miami
I jus threw in the much hated NGK IRIDIUMS and my car runs perfect... They're gapped to 28 and dont blow out, and it idles perfect... Strong pull all the way to 7k rpm.
ahmed
150
cleveland
well from what i hear there bad and will melt pistons on high boost
86_sports_1jz
slow 700hp build...
Aug 27, 2006
1,217
OK
you can try these plugs, they are colder than stock just pick the one with the right heat range for you
R5672A-8 ngk copper (i used these)
R5672A-9 ngk copper
R5671A-10 ngk copper
BKR6EIX-11
BKR7EIX-11
BKR8EIX
BKR9EIX
terror
Antibliss
Jun 13, 2008
242
Alaska
ngk 4644's aka bkr7e, alot of members are running these at high boost, just bought a new set today too :icon_razz
Supra-Man18
357
miami
WHOA.. lol I kno a couple 850whp+ supras That uses these.. 3 of them daily driven.. No probs what so ever... BUT I have heard other things about the iridiums.. so far i have experienced none. I actually kind of like them.
