I just bought some plug for my 1j and whats the recommended gap for them? i searched but couldnt find anything. i got the ngk 6097's so are they gapped correctly out of the box?
suprahero;1215717 said:You'll just have to run them and see how your car likes the gap that they're set at. I know from personal experience that my car won't run without them being gapped to .022
The stock gap on them plugs is probably .032 which may run perfectly for your car. If I try it @ 17psi of boost then my car breaks up horribly at 4500 rpm. If you're on stock twins then you may be o.k. since you won't be running very high boost. It's easy to change them out, so try them like they are. If your car starts breaking up, lower the gap about .002 and try them again. Good luck.
supra1008;1217778 said:THANK YOU SUPRAHERO! I think I found my problem. My car has been breaking up after I went single and up the boost. Everyone has been saying your running lean. I've been thinking about sparkplugs. So I got an AEM Wideband just to make sure. its full on rich at full throttle. I'm going to check my spark plugs now! THANKS! Now did you mean gap to .002 or .022?Chris.
sai_supra1jz;1218413 said:Gap .22. Please don't go .022.
86_sports_1jz;1220027 said:can anyone help me with the nitrious and spark plug issue?
