I'm looking for ideas on my soon to be sound system. I don't want one that that is overly exspensive, but I want one that sounds good & all the speakers are installed in the stock places (ie it won't fill the back hatch). Any advice?
Evilempire1.3JZ-GTE said:infinity kapa 4" front
infinity kapa 5"1/8 rear
eventualy maybe 1-2 10-12" wolfer in rear but down the road.
I ripped out the cheap old thin speakwire ran monster wire to replace them.
for the player i use a pyramid graffic EQ active (inculdes amp inside) and an IPOD to plug into the front 60 gig juke box amp speakers all i need.
Modifications are fine as long as they're not seentheprodigy79 said:Hey Rakkasan,
Fill us in a little bit.. What are your goals with this? Why are you changing your system (replace current setup, substantial upgrade, etc...)?What type(s) of music do you listen to? If you had to choose, loud or clean?theprodigy79 said:I want to upgrade the entire system. I'm looking for a double DIN in dash (non motorized) DVD/NAV & some new speakersHow much are you realistically looking to spend (keep in mind, it's better to do this right the first time and be happy with it, than to not be satisfied and have to shell out more to upgrade later)?theprodigy79 said:definitley cleanI know you said you want your speakers in stock locations, but are you willing / able to do a bit of simple customization (not necessarily anything seen when the car is put back together, but modifications to fit different size speakers that may better suit your tastes / wants... I know I like to keep my rides appearing stock)?theprodigy79 said:I'd like to keep my total around $800 or less....
-James
I want to upgrade the entire system. I'm looking for a double DIN in dash (non motorized) DVD/NAV & some new speakerstheprodigy79 said:Hey Rakkasan,
definitley cleantheprodigy79 said:What type(s) of music do you listen to? If you had to choose, loud or clean?
I'd like to keep my total around $800 or less....theprodigy79 said:How much are you realistically looking to spend (keep in mind, it's better to do this right the first time and be happy with it, than to not be satisfied and have to shell out more to upgrade later)?
Modifications are fine as long as they're not seentheprodigy79 said:I know you said you want your speakers in stock locations, but are you willing / able to do a bit of simple customization (not necessarily anything seen when the car is put back together, but modifications to fit different size speakers that may better suit your tastes / wants... I know I like to keep my rides appearing stock)?
-James
theprodigy79 said:$800 is a pretty limiting price for in-dash nav and speakers, but I did a bit of resarch and it looks like it may actually be possible to still get decent products and keep you around this top.
For the nav, your best bet will be to go used... I looked on eBay, and it appears you can get a hold of a Pioneer AVIC-D2 from anywhere between $620-$700. While this is definitely not Pioneers highest end unit, it is far superior to any other nav units in its price range (retail price range, not even referencing the above price it can be had for). It's a double din (as you prefer), and is a very straight forward, easy to use unit with a lot of pretty useful features. If you go this route, just make sure you purchase from a reputable buyer with a substantial amount of feedback from Buyers. Also, check the item description and make sure it comes with everything you need, and the item is in good condition.
That's DEFINITELY where I would start... Now, for speakers:
If you're dead set for keeping at $800 or under, you have around $150 left to play with at this point (assuming you get the unit for a middle ground in the range I gave you). Let's not even consider amping at this point, but let's make sure we get some speakers that will allow upgrade to the usage of an amp in the future (so something that will sound good running off the head, but something that will benefit from being amped... this way you don't have to go out and buy new speakers if you decide to upgrade a bit in the future).
First off, what kind of music did you say you listened to? This does make a difference.
Second, you have a couple options in this car for speakers... Do you prefer to run 4 speakers and be more "immersed" in the sound, or would you be happier with running a single pair of higher quality speakers up front with good staging and superior sound? Keep in mind, if you're going for two sets on a tight budget you'll have to step down quality... Whereas if you go for a single pair of GOOD quality speakers (which can easily be had for your leftover $$$), you will have that much better sound, and the option to add the rears in the future if you so desire... I looked around and it is possible to get 2 pairs of pretty good speakers in your range (or a bit over), but I'll leave that decision to you.
Let me know the answers to those questions before we go any further.
Thanks,
-James
