these arent tooo technical, but i feel like this is still the right place to ask... thanks in advance for any insight you guys can offer.
1) getting ready to put stuff back together. this is what i've put on my "to buy" list. this is a straight up "oem" rebuild, so nothing too fancy. i am trying to accomplish this as cheaply as possible.
7M Thermostat $15.95
7M Timing Belt $34.00
Water Pump $55.00
7M Timing Belt Idler Pulley $38.00
Silicone hose kit $280
Arp head bolts $100
the only other major thing i plan to purchase that i havent listed yet are gaskets. i've had my eye on a felpro gasket kit from suprasport for $290. Id rather go OEM from Toyota, but I don't want to buy each gasket individually. I already know I've removed (and will require new) the headgasket; gasket between upper/lower intake; gasket between intake and head; gasket between exhaust mani and head; gasket between turbo and exhaust mani; egr cooler gasket; CPS gasket; water outlet gasket; valve cover gaskets. i'm sure there are more, but those are the ones i KNOW i'll need. pretty sure they will already add up to around the cost of the felpro gasket kit if i purchase them individually from a dealership.
other small things i plan to buy are all new studs and nuts for the hot side (head -> manifold, turbo -> elbow).
so i guess my questions are:
#1: what is the best way to go about procuring the gaskets i'll need.
#2: is there anything else that i absolutely should replace while I have the top-end disassembled?
#3: how can i tell the difference between an oil passage and a coolant passage in the block? i ask because it seems that it is more important to keep the oil passages clean and free of debris. my coolant system is dirty as it is and i plan to flush it thoroughly once the shortblock is reassembled. the oil passages arent so easily cleaned out, and though i plan to change the oil immediately after i get the car running again, id rather keep that system as clean as possible (not to say im gonna cram shit into the coolant passages. more just that i am going to take extra precautions to keep the oil passages clean.)
#4: what is the correct tap size to use for chasing the threads in the block? and for chasing the threads in the head for the exhaust manifold studs?
that's it for now, though i'm sure there'll be more soon.
thanks for the help!
p.s. here is my rebuild thread... http://www.supramania.com/forums/showthread.php?158569-The-Rebuild!-(90T)
Water Pump $55.00
Arp head bolts $100
