Alright so I am at wits end here, I cant really think of anything else that could be doing this, but here is the problem.
As noted the car smokes and I mean smokes a lot. If you have ever done a fuel induction service and didnt have the car revved up enough and the cleaner puddled in the intake you have seen the kind of smoke I am talking about. So thick it will block out my entire house and street in seconds. Alright so the rundown of the car.
Car is a 88 na bone stock, turbo swap from 89 jdm. Everything is stock except an hks mgh and arp studs. Took the motor apart before installing and replaced all the seals, except valve seals(more on this later). I checked all the specs and bearings and rings and everything is in spec.
So I got the motor in the car started it up and it runs great except blue smoke. So checking #6 there was oil on the valves and on the piston, so I put a new set of valve seals in the whole motor. Cometic valve seals, looked like polyurethane. Anyways with that done no more blue smoke but a lot of white smoke. There is no coolant in the car just straight water, and even with no water in the engine it is still smoking white, and even a co2 tester didnt pull up any co2 in the water. So head gasket should be out of the question.
Now the cats were broken up so I cut out all the cat material so its straight piped, but its a factor stock exhaust. There are no codes and the car runs perfect, probably better than perfect. The only known problem is the bov is toast complete pass through. New one is on the way. After I take the car out and drive it for a while the smoke settles down, but letting it sit and run and warm up will not make it go away. And again if this were a little smoke I wouldnt care but it is a lot. Coolant is always full and resivour stays at same level. I have heard that there is something you have to do to a jdm motor or it will smoke but not sure if i believe it or not.
So question is can anyone think of anything that would create this much smoke? Also there is no blue in it at all and it just smells like normal exhaust. Could this just be from not having any cats on it or any other ideas? Once I get the bov and install it I am going to drive the car on a longer trip, has seen probably 10 2 mile trips since putting it in. I am going to take it to get a 5 gas analysis done to see if maybe something there will show me anything but just looking for some ideas before hand.
