***SM Member Horsepower List***
Slow66
I think with my dipstick
Apr 3, 2005
1,457
Newington, CT
Here it is folks, a list of power levels that will actually be updated.
To go with our 1/4 times list, we will now have a list of the top dyno results for 7M, 1J, 2J and "other" Toyota powerplants. We DO want to see the posted sheets but, if possible please include a direct link to the graph, or a thumbnail of the graph to help keep the thread a bit cleaner. Thanks!
There will be 4 sections. 7m powered, 1j powered, 2j powered, and Other - ie, 5m, 1G, 1/2uz, etc. I will do top 30 for 7m powered, since that is the majority, and top 15 for everything else.
Edit by Grimjack: Slight change - you still need to be able to get into the top 30 / 15 to get on the list, but I won't remove people who get pushed down past the bottom.
Make your submission by posting the following:
  • Your corrected wheel horsepower and torque.
  • Engine type.
  • Dyno sheet or video. I will work on the honor system that it is actually yours.
  • A *basic* mod list. Preferably ones that affect your power levels - save the details of your color shifting paint for a different conversation, please.
Let the games begin.....
7M-GTE powered
  1. mibrum - 1340whp - 91mm turbo, 40psi, stock crank and block, pauter rods, JE pistons, Jerico 5spd, 1mm oversized valves, ferrea valve train, ported head, TEC3r standalone
  2. Elli - 885whp/657wtq - BC272° Cams, BC Springs, JE-Pistons, Eagle Rods, S475SX, EMS8860
  3. upgradedsupra - 853whp/642wtq - JE's, TI rods, OEM crank, head work, custom TED billet cams, MoTeC M600, MoTeC E888, MoTeC SKM, M&W ignition, AIM DD, Weldon 2345, RC1000's, ATI TH350, Moly driveshaft, Custom ATI crank damper, Ron R FFIM.....
  4. kwnate - 842.98whp/683.20wtq - gt4067, AEM, ported head, TED 268 cams, Ron R. FFIM, aeromotive pump/1000's, tilton triple carbon/carbon, w/ n2o
  5. toyotanos - 788whp/674 rwtq - 7M Eagles/83.5mm JE's, AEM, 1350's, E-85, Billet 6765 @ 31psi, +1mm valves, dual springs, P&P, BC 272 cams
  6. X-man - 753 rwhp/589 rwtq - stock internals, gt42 @ 30 psi , 1000's, aem
  7. MK3Brent - 641.24whp/574.20wtq - GT4088, walbro/550s, VPC/AFC
  8. mark1987supra - 618whp/571wtq - 7MGTE, PROEFI, E55, SP61, 25 psi, 1200cc inj., BC 272 cams, Weisco 20 over, Crower rods, Hks Stopper, ARP Head and main studs.
  9. NashMan - 585whp/540wtq - PTE 67mm @ 24psi, BC272s, 850cc injectors, microtec lt10, a1000 fuel pump
  10. mytmk3 - 566.58whp/929wtq - Mp t70, tial v44, Toda cams Titan cam gears, comp cams valve springs, Je's and eagles, 1200cc injectors + dual walbro's, 3.5" catback 3"downpipe 2.5"&3" ic pipes large fmic, Ffim q45 tb, Link g4 ecu, Os triple plate clutch
  11. Supra8795 - 551.12whp/472.39wtq - mp T70, 750's, single walbro, afpr, , 3" exh., 4" intake, VPC/AFC, port/ polished head, 272 cams, Ron R ffim, 4" xspower ic, stock bottom end, cometic hg.
  12. HKS_TRD - 540whp/XXXwtq - GT35R, Motec M800, UNPORTED HEAD, HKS Cams, Greddy Intercooler, Stock intake manifold, Turbo A throttle body
  13. BostedSupra - 531whp/XXXwtq - AEM, SP63, 40 over JE's, Crower rods, stock crank, webcams 244, stock head, SP manifold, SP down pipe and mid pipe, apexi GT-spec cat-back, aeromotive 1000, greddy 660cc, apexi 3 row innercooler
  14. teamslow - 526whp/475wtq - Precision 6765 journal bearing turbo.81A/R 18 psi on pump gas, ID1000cc injectors, Walbro 400, AEM
  15. tekdeus - 515whp/503.4wtq - 28psi, stock 7m with MHG, 62mm billet HTA3586, SAFC, Lexus / 550s, water / meth injection
  16. mytmk3 - 515whp/435.4wtq - Mp t70 tial v44, Toda cams Titan cam gears, comp cams valve springs, Je's and eagles, 680 injectors + single walbro, 3.5" catback 3"downpipe 2.5"&3" ic pipes large fmic, Ffim q45 tb, Link g4 ecu, Os triple plate clutch
  17. supra90mkiii - 513whp/455wtq - 11.6:1 afr, sp61gtbb, ported head, bc 264 cams, ffim, 680cc injectors, 24psi, factory untouched ex manifold.
  18. polobai - 510whp/466wtq - Built 7m, (wiseco pistons, eagle rods, etc.) Port and polished head, three angle valve job, 272 bc cams, valve springs. Gt4082 at 20psi with 550's +meth on 93 octane. Maft pro @ 11.5 afrs.
  19. topgear - 505.3whp/527.4wtq - MP T70, walbro/1000's, Ported head w/3 angle valvejob, Eagle/Weisco combo, HKS Stopper 2.0mm, Fidanza Flywheel, RPS Bronze Stage 5, custom mani and exh., BIC IC, AEM
  20. jonny87turbo - 500whp/443.4wtq - 20psi, 7mgte with comp vrp64mm bolton turbo, 3in exhaust, 40 over with cp pistons, snowperformance meth injection, 2.5in intercooler piping, DM intercooler, AEM EMS, 1000 ID injectors, dual intank walbro fuel pumps
  21. MarkIII4Me - 467whp/426 ft/lbs - *JE Pistons * Crower Rods * Crazy Head Porting * Custom Raised 7M turbo Cams * ARP Head Studs * HKS Stopper HG * AEM Cam Gears * Turbonetics Hi-Fi 62-1 Bolt-on Turbo * 5" Blitz SUS Filter * 1JZ FFIM w/ all provisions * Delta Fin Intercooler * Greddy 720cc low impedence Injectors * Aeromotive AFPR * Tial Q Bov * Trust Power Extreme II Exhaust * BIC Ceramic DDP * Fluidyne Radiator * Flex-a Lite Fans * Spec Stage3 Clutch * AEM v1 Rev.B Mod.C EMS
  22. yota8791 - 461whp/411wtq - je's, stock rods, HKS 2mm MHG, P&P head, garrett T67 @17psi, hks intake, ets 32x12x3.5 fmic w/ greddy pipes, Sard FPR, walbro/870cc bosch injectors, ACT stage 3, 3" elbow/dp, HKS super dragger
  23. survyor2 - 440.6whp/431.0wtq - sp61 kit, HPF ic kit, je/eagles, 3"exhaust, spec3, fidanza flywheel, 550cc, lex afm, safc2, avc-r
  24. gixxer750 - 432.09whp/XXXwtq - t66 @ 15psi, FFIM, aem
  25. wardog - 431.74whp/426.47wtq - ct26/60-1 @ 18psi, K&n, maft pro, ddp, 3"exh, walbro/550's, 2.5 hardpipes/FMIC, evcEZ ,safc2
  26. suprakid24 - 431.23whp/441.91wtq - GT4088r @ 18psi, AEM ECU, 750's, HPF IC, stock internals
  27. aye mate - 430.91whp/390.50wtq - SP61GT,stock bottom end, 3" Exh, Walbro/stock injectors, Lex AFM, FMIC w. 2.5 hardpipes, 2mm cometic/arp's, Spec Stg 2 Clutch
  28. crisp - 427.14whp/368.22wtq - HKS alphabet soup on 550cc injectors off a single Denso MKIV pump, stock bottom end, 17.6psi
  29. pln - 425.3whp/XXXwtq - gt35r @ 18psi, mapecu2, rc550, mid-ported head
  30. UberSupra - 423.16whp/401.67wtq - SP61GT, Stock Bottom End , 3" Exh, Walbro/550cc/Lex AFM, Spearco IC w/ 50mm Hardpipes, Spec Stg 3 Clutch
  31. Fuzz420 - 422whp/401wtq - 17psi, Rebuilt GTE, Probes, prepped rods, ARP, HKS MHG, stock head, JT56 Turbo, RC550s, Wally, Aeromotive FPR, Maft Pro
  32. 92nsx - 417.41whp/382.81wtq - 40 over probe pistons, eagle rods, HKS MHG, BC 1mm oversized valves, BBC springs, BC 272 cams, A1000, afpr, Lexus / 550s, FFIM, BOSS Sr. - P-trim 61mm, GTS housing triple ceramic ball bearing turbo.
  33. sunnysupra - 413whp/475wtq - stock head, crank, rods. JE 20 over. hks HG. stock upgraded ct26. walbro, vpc/afc, spearco intercooler
  34. paradox616 - 411.5whp/379.6wtq - stock rebuilt motor, cometic/arps, 3 angle valve grind, T61 @ 16psi, 3" turbo back exhaust, haltech e6x, 835cc injectors, walbro 255, 24"x12" intercooler
  35. kmfdmk - 406.63whp/392.33wtq - 57 Trim CT-26, 550's, Maft-Pro, Tial 50mm, 2.5" IC, 3" full Exh. 12x3x36 FMIC, Probe Pistons, Eagle Rods, Knife-Edged Crank, XTD Lightweight Flywheel, Stage III Clutch, P&P Int. Head & Exh Mani. Dual Oil Filter w/ Oil Cooler & Thermo. Crank Scraper
  36. soup - 405whp/391wtq - rebuilt 7m w/stock internals, mhg w/arp studs, lucas pte 580's, lex afm, greddey eman blue, basic harness, t4 60 trim / t3 .58A/R hot side at 14psi, BIC tube manifold + 3.5" exhaust, NPR intercooler
  37. Supra0089 - 402whp/408wtq - JT62 turbo at 16psi, HKS MHG & ARPs, RC550s, DDP, 3" exhaust, Spearco FMIC, Wally, built a340e
  38. KevinM - 391.36whp/378.69wtq - SP63 @ 17psi, MAF Translator, 720cc inj, SAFC2
  39. pimptrizkit - 375.49whp/334.84wtq - 57 trim ct26, 2.5" hard pipes, fmic, stock injectors/pump, n/a cams. full 3" exh. no cats, rebuilt head, .20 over, 2mm mhg, stock rods, MAFT Pro
  40. sethron71 - 372.47whp/363.32wtq- 57 Trim CT @18psi, Lex AFM, Walbro/550's, S-AFC, K&N, Divorced 3" DP, Full 3" Exhaust, Long Runner FFIM w/ 3.25" TB, FMIC and 2.5" IC piping, 2MM MHG w/ ARP's, Fidanza w/ SPEC Stage 3+, One-Piece driveshaft
  41. CajunKenny - 367whp/345wtq - JT62 @ 15 psi, PTE550's, Walbro, AFPR, Maft-Pro, Fidanza FW, Fan Delete, Extrude Honed Intake Manifold, DM IC, 2.5" IC Pipe, Blitz Elbow, 3" SuperDragger, Test Pipe
  42. rodel - 365.6whp/373.4wtq- aem ems, 60 trim ct26, 550 injectors,3" exh.
  43. avp23 - 364.18whp/373.94wtq- je pistons, eagle rods, light flywheel, spec 3+ 60-1 trim, 550cc, lex afm, big fmic, 3inch exh. afc, avcr.
  44. tsupranami - 363whp/- 1.0 BAR, untuned, stock internal 7M-GTE, Boss Sr. 57 trim, 550 injectors, LexAFM, Apexi SAFC and AVC-R
1JZ-GTE powered
  1. Albert - 722whp/618wtq - 30psi on stock block 1jz. 1200cc, e85, dual 044, T70 turbo. .84ar, 3"dp, 4" exhaust, 272 cams. 20° timing. Tuned by tony at UMS on Proefi 128
  2. 525gte - 641whp/500wtq - 30psi stock rods. Cp 9to1 pistons. 1200cc e85 precision 6262. 82 ar bc 264 cams ms3 pro single aem320 in tank pump.
  3. 2JZ_MA70 - 602.6whp/550.8wtq - stock motor GT35R-HTA, 3" turbo back, Tub manifold w/ 60mm tial, 24x12x4 Int, 1600cc, Twin Walbros, AEM EMS and C2DI
  4. Turbo Drifter - 550.7whp/~460wtq - IHI RHC7 20p @23psi, 550's, S-AFC, BCC, 3" exh & dp, Spearco 24x12x3.5 I/C
  5. suprahero - 543.2whp/437.3wtq - gt35 @ 24psi, 3" exh, crower 272's, DM FMIC and hardpipes, Stinger, walbro/624's
  6. 10secdream - 482.46whp/406.03wtq - Jun 264/272cams, Bosch 044 fed by stock pump, MK4 550s, Apexi IHI C7 Turbo @ 22psi, 3" dp/BIC 3.5" Catback, Devils Own Meth Inj kit w/ M14 nozzle, Stinger EMS, ARC 18x12x4 IC w/ 2.5" piping
  7. Torque - 471.78whp/381.94wtq - stock 1jzgte motor, sp63 turbo, 3 inch turbo back exhaust, 24*12*3 inch intercooler, 2.5 inch intercooler piping hot side and 3 inch cool side, SAFC, MK4 550cc and walbro in-tank fuel pump.
  8. Yotaholic - 451whp/390wtq - HKS twins @ 19psi, Spec Stage3+, Raptor Racing 3" ss Exhaust w/HKS Y pipe, 24x12x3.5" IC, Emanage Ultimate, Bosch FP/sard 650's, Mines Ecu, usdm 2J cams, Titan adj cam gears
  9. becauseican - 449whp/410wtq - USDM 2jz custom machined cams, MK4 pump, BIC top feed rail w/750's, DBB SP61 .58 a/r, BIC custom 3.5" DP/Thunder catback, Haltech PS2000 EMS, AEM water/ Meth kit, Garrett/ Spearco custom 24x12x3.5" IC, BIC custom 2.5" IC piping
  10. honestabe - 399.95whp/346.54wtq - Driftmotion 60-1 .70 A/R twin scroll turbo @ 16psi, DM twin scroll manifold, 3" turbo-back exhaust, SAFC NEO, JDM 2J 440cc injectors, CAI, FMIC, 2.5" IC piping
  11. Viggs - 392whp/331wtq - DM67 kit, 93+meth, BC 272 cams, 780cc top feeds, dual walbros, cracked coil packs
  12. lazer1100 - 380.9whp/418.1wtq - Stock 1jzgte , rebuilt twins at 18psi, mines ecu, SAFC 2, full three inch fencepole and turbosmart manual boost controller
  13. destrux - 369.5whp/388.1wtq - Stock 1JZGTE, Holset HY35W on tubular manifold, 46mm wastegate, 3" intake w/ K&N, 3" turbo-back exhaust, 100cell metalcat, Circuit 7 MBC, 2.5" IC piping, JDM Sport 3" Intercooler, AFC Neo, 440cc injectors, Walbro 255 HP, vF gauge, PLX wideband, SSI-4 datalogger
  14. brett - 346whp/290wtq - GT4082 .86a/r @ 11psi, 440's, Crower 264's, S-AFC, Aeromotive AFPR, Dual Walbro's, RPS Max 6-puck
  15. Zerocool - 331whp/299wtq - T66, 3inch exh, FMIC w/ 3" hardpipes, SAFC II, JDM MKIV 440's, Walbro 255
  16. te72 - 320.45whp - 89 Supra, 1jz, stock twins @12psi, BC264 cams, ported/polished, 3" exhaust from turbos back. Stock AIRBOX.
  17. viperkillertt - 300.6whp/298.7wtq - Stock Twins@15psi, 12x24x3" ic, Blitz ecu, Full 3" exhaust w/cat & Y-pipe
  18. MK3Hitman21 - 300.54whp/310.06wtq - Completely stock 1j, with emanage blue and boost controller.
  19. sixpatch - 297.57.5whp/319.98wtq - AEM wideband, SAFCII, AVCR, Driftmotion IC & hardpipes, Wally, Koyo rad, Southbend Stage 4 clutch, 17.21psi
  20. xsjado - 292.5whp - stock twins@12.7 psi, 2.5" y-pipe to 3" exhaust, 24x12x3 FMIC, Malpassi FPR, SAFC-II, AVC-R, Single plate clutch, Titan Cam Gears -5 exh/+1 int
2JZ-GTE powered
  1. 2jzmk3 - 1037.1whp/XXXwtq -
  2. jt2ma71 - 844whp/646wtq 26 psi. Dry sumped. Ron R. intake manifold, Ron R. exh manifold. Ron R. 4" exh w/ burns muffler. GT42R. MoTeC M820, MoTeC CDI8, MoTeC E888, MoTeC ADL, MoTeC TCMux, MoTeC etc.
  3. nathaninwa - 778whp/636wtq 26psi, MS3Pro, Wiseco 9.5-1, K1 rods, S1's, 6466 divided .84, staged injection with 1200cc secondarys on A1000-116 race gas.
  4. mrsuprafreak - 716.94whp/686.39wtq - Borg Warner 80mm Stock block and stock head 272 HKS, 850cc injectors, 4inch Custom exhaust.
  5. hottscennessey - 677.86whp/580.17wtq - 2JZ-GE NA-T; Master Power T70 .68 A/R., Bosch 044, 870cc injec
  6. rodel - 668whp/615wtq - Stock vvti 2jzgte, 67 Comp Turbo, 1000cc injectors, 25 lbs boost, e85, aem v2.
  7. Nick Stonawski - 619.78whp/523.49wtq - T88-33D, 720s, hks 264's, Exedy twin plate clutch, g-force ECU
  8. suprahero - 614whp/561wtq - 1j head, pt67@25psi, 3" dp to 4" exhaust, SARD 624cc inj., BC 272 small core cams, CP pistons, Eagle rods, DM IC & piping, Drewgo mani, Tial 44, meth inj, Stinger EMS, Apexi AVC-R, Stock intake, HKS DLI
  9. Nick 95 6sp - 613.8whp/590wtq - 22psi, water / meth injection, Twin Garrett GT2860's with Tial exhaust housings on V-band moded HKS manifolds
  10. SirLoki - 609.72whp/541.36wtq - AEM ems, HKS t04z, HKS 264's, 720's
  11. leecheater - 579.7whp/588wtq - GT3582r DBB, US OEM cams, 24x12x4 IC, , Aeromotive FPR and fuel pump, HKS replica 50mm WG, Greddy SP Cat Back, 1pc jawsgear Steel Driveshaft, 1200cc injectors, AEM ECU, tuned with E-85
  12. Grimjack - 578whp/557wtq - 5 speed, dbb 67mm turbo, 890cc injectors, water meth, Vipec v88
  13. dok33 - 533.1whp/496.93wtq - 93 2jzge, TT hg, 7M ECU/Harness, Lex AFM/SAFC, 880cc inj/E85, SSAC T4 Manifold, MP T70, 50mm wg w/ 15psi spring,Aeromotive FPR, Bosch 044 pump,Chinese dp to 935 3" DIY exhaust
  14. jmcboost - 533whp/461wtq - 2JZGE-T, 1.8MM HG, Master Power T-70, Stinger 4424 EMS, Web cams 264, R-154, 780cc, Wally, FFIM
  15. NewGen - 516.74whp/436.12wtq - 2jzgte Stock Engine, Chinese gt45, AEM V2, 91 octane @18 psi
  16. Torque - 420whp/404wtq - Borg warner 83-75 turbo, Cast manifold, 3" down pipe to a 3" Greddy SP cat-back exhaust, Sard 800cc injectors, Walbro 400lph fuel pump, 12x24x3 intercooler and a AEM V1 EMS.
  17. gurley0916 - 417whp/397wtq - Aristo 2jz-gte, R154, 3'' Exhaust 4'' Intake, Garrett 67mm turbo with .70 divided housing & manifold, usdm 550cc injectors, MAPECU tuner, Lc-1, Walbro 255, Dyno was at 19psi
  18. tissimo - 394.91whp/389.76wtq - Stock twins, 18 psi, fmic, 3" exhaust
  19. bigdaddygrip - 392whp/330wtq - 1j head, 264 BC cams, 550's, T67 turbo .58 a/r, Map-Ecu 2, 93 octane + Meth
"Other"powered (1UZ, 5/6M, etc.)
  1. darkspeed - 421whp/401wtq - 6m, T61, 3.5" DP, HKS mani/40mm WG, Megasquirt EFI, walbro/720's, FFIM w/ ford tb, spec stg 3, npr IC
  2. limequat - 249whp/259wtq - 4.2L VORTEC swap (inline 6, aluminum block), 3" exhaust and custom tune
honestabe
Happy as hell :D
Jan 15, 2006
3,713
Mount Vernon, WA, USA
1JZ-GTE, cold air intake, 3" exhaust (catless), 1-piece 11 lb. aluminum DS, ACT clutch kit, SAFC Neo, AEM TRU boost gauge/controller, 16 pounds of boost, stock twins, Aeromotive FPR, and tuning by John at RRev Motorsports. 296.55 RWHP, 270.76 RWTQ.
xsjado
Engine bling!
Jul 15, 2007
252
Melbourne
1JZ-GTE: 2.5" y-pipe into full 3" exhaust, 24x12x3 FMIC, Malpassi FPR, SAFC-II, AVC-R, Single plate clutch, Titan Cam Gears -5 exhuast/+1 intake, 12.7 psi on stock twins, 292.5 RWHP(218.1 RWKW), 601.7 RWTQ(815.8Nm):aigo: on a partial tune(never got to finish tuning :(). Blue run is good run, red run you don't wanna know :(
pimptrizkit
thread killer
Dec 22, 2005
1,572
vancouver Wa
7mgte,stock ct26, 2.5" hard pipes/t-bolts , front mount ic. stock injectors,stock fuel pump-i also was running out of fuel. n/a cams. full 3inch exhaust not cats. head had a full rebuild and 3angle grind.
.20 over pistons and rings, 2mm mhg, .10 under bearings. resized,polished and balenced rod's , knife edged crank and remove 1.35lbs
running maft pro, had the boost controller set to 12psi and it peaked at 13. or so and leveled back off.
all tuning was done by my self.
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
2JZ-GE NA-T; Master Power T70; .68 A/R., Bosch 044, 870cc injectors, Stinger EMS, Sethron FFIM, Q45 TB, Methanol injection.
573hp/592tq
Sawbladz
1,727
Oshawa, ON, CA
7MGTE
281 hp, 337 tq
Stock turbo and fuel, rerouted divorced downpipe, 3" exhaust and cat, 13 psi peak and leveled to 10.
X-man
member
Dec 5, 2005
309
Pulaski,Va
here is one of my 600rwhp plus charts on my stock internal 7m-gte, SP67,680's,the alphabet soup and alot of fuel.
here is the 753 rwhp sheet on stock internals, GT42, 1000 cc injectors, HKS DLI and an AEM
Sean
aye mate
Hiatus over.
Maryland
7M-GTE-430rwhp/390ft.lbs
http://img.photobucket.com/albums/v193/lastlaugh207/SupraDyno.jpg
Mod list:
SP61GT (wastegate boost)
JBL o2 Housing
3" Exhaust (no cats)
Walbro 255
Aeromotive AFPR
DriftMotion Fuel Feed line (removed pulsation dampner)
Rebuilt OE Injectors
K&N FIPK
Lexus AFM
DriftMotion FMIC
2.5'' Cooleeze Aluminum Pipes
Greddy RS BOV (recirculated)
Cometic 2mm MHG
ARP Bolts (torqued to 100ft.lbs)
CompCams Valve Springs
Spec Stage 2 Clutch and Pressure Plate
165k miles on the bottom end, transmission and rear end!
darkspeed
138
Montgomery, AL
www.pbase.com
Mkii - 6M-GE - stock rotating assy.
T04e/T61 w/3.5" DP
HKS shorty manifold/40mm WG
Megasquirt EFI fuel n spark
720cc densos
SPEC stg3+ (W58)
walbro 255
FFIM/5.0L Ford TB
NPR intercooler
376/390
Final Pull
Thanks again for a top-notch forum!
Slow66
Apr 3, 2005
1,457
Newington, CT
Sorry Darkspeed for the couple day delay....didnt have much time to get online at tx2k8, but i'm back now and got you up there :)
supra8795
193
Illinois
Hey Slow I have been putting your manifold to good use.
750cc injectors, single walbro, afpr, mp T70 turbo, 3" exhaust from the turbo back, custom 4" intake, afc/vpc combo, port N polished head, 272 cams, Ron R ffim with custom intercooler pipes(2.5 hot 3" cold, 4" xspower ic, stock bottem end with a cometic hg.
YAY!!! I get to be on the top for a few days :) I have done some tweaking and i think it will be around 330rwhp when i dyno in about a month :)
Current Engine Stats:
1jzgte
Stock Twins
12x24x3" intercooler
AVCR running at 15lbs
Blitz Reprogrammed ecu
Full 3" exhaust with china Y-pipe installed
Cat still installed :(
Oil Pressure 90 Lbs at full throttle, 40 at idle
Fuel: 92 octane, oxygenated winter gas
This is a overlap of my stock boost run and 15lbs. about a 30 hp difference.
Clint
AzSupras
Apr 4, 2005
1,463
7
Mesa, Arizona, United States
I dynoed Saturday wile it was 98° out here in the valley of the sun :)
331rwhp and 299rwtq @ at 15lbs
Mods
- Turbonetics HP-66 aka T-66
- Driftmotion 50mm wastegate
- 50mm TIAL bov
- Full 3” exhaust W/ 4” Mugan racing medallion
- Tubular drewgo T4 manifold
- 3” custom drewgo downpipe
- Blitz dual sbc boost controller
- (ForcedFab)custom 24x12x3 intercooler
- (ForcedFab) 3" custom hard piping
- Apex'i SAFC II
- JDM MKIV 440 injectors
- Greddy timing belt
- Aeromotive FPR kit
- Walbro 255 fuel pump
Dyno sheets
http://public.azsupracentral.com/index.php?dir=Dyno+Day%2FClinton+Griffin/
avp23
87
Washington
hey, my i please get added to the list?
mkII 7mgte
je pistons eagle rods light flywheel, spec 3+ 60-1 trim turbo 550cc, lexus afm, big front mount, 3inch exhaust turbo back. AVCR Apexi AFC apexi
thanks
I haven't had my 1.5jz dyno'd for peak numbers yet, but on my 1jz, I made 543rwhp.
[URL=http://s36.photobucket.com/albums/e11/supraheroes/dyno%20videos/?action=view&current=5315rwhp.flv] [/URL]
Here's one I made to get on www.gtepowered.com The Mark that I get is Rakassan and I barely got him for first place on Duane and Miguel's site.
[URL=http://s36.photobucket.com/albums/e11/supraheroes/dyno%20videos/?action=view&current=530rwhp.flv] [/URL]
EDIT for Mods list: Crower 272small core cams, SARD 624cc injectors, Garrett gt35r, Stinger standalone, 3" Exhaust from turbo back, single walbro fuel pump, Aeromotive fpr, Koyo racing radiator, driftmotion ic piping, driftmotion exhaust manifold, hks replica wastegate, tial bov, Apexi avc-r set at 24psi. Pretty much exactly what Mike posted below.
